I came across a TV12 AM for sale.
It looked as though it was a TV22 because the CRT mask is the same as the TV22.
See below.
Apparently the TV12 used an electrostatically focused tube which required the focus to be adjusted periodically when the set was used due to component tolerances .
The use of a magnetically focused tube resolved the problem.
What seems strange is that the TV12 AM was a TRF receiver, Superhet technology had been around for a while by this time so why design a set around TRF?
Check out the following link -
http://www.friendsreunited.co.uk/televi ... 01013b56c9
Andy
I saw a TV12 advertised a short time ago and noticed that it had the TV22 mask (4 x 3) instead of the normal 5 x 4 mask. I wonder whether this is the one I saw! Checking on Jon's excellent website, the TV12AM was manufatured as late as March 1950, the year in which the aspect ratio changed. He also mentioned the the TV12AM had a different main chassis so was obviously a much closer relative to the TV22 than the earlier TV12s. So the only accurate check for the TV12 is the RF deck with its red EF50s (a site which I love to see, all those red cans!).
I think there was an overlap in manufacture of the TV12 and the TV22.
I have a TV12AM, but the back panel is stamped with TV22, but with a badge stuck over the top with TV12AM on it.?
Also was there ever a TV12BM?? On jons page it states that 'B' was Birmingham model.
Jon
Jon,
The one I saw had another badge stuck over the one stamped on the back.
The RF deck has EF50s.
I would rather like it but funds are rather stretched at the moment.
It is on Ebay
Andy
Yes that sounds the same as my set.
Am I right on thinking that the AM version is magnetically focused with a lever like the TV22 and the TV12 had electromagnetic focusing with a pot for adjustment??
Jon
It would appear so from the photograph of the back of the set.
Andy
There is a TV12AM on ebay at present, but at 125 pounds its a bit steep. It has the EF50 valves. I wont put the link as its very easy to search.
Stephen
Hi freya,
That is the one I saw!
If I lived close by I may have been interested even at that price.
As I am too far away it will have to go elsewhere.
I still after a TV12 though.
Andy
Stephen
A while ago that would have been considered a bargain. Both mine cost way more than that and I mean way more! It was back when the market was less depressed and they were commonly fetching £300-400. Oh how times change.
I think I paid £102 for about 18 months ago.
I haven't done anything with it yet as I can't get the screws out that hold the chassis into the cabinet!
Jon
Stephen
Thank you Stephen. Please put any eBay links in 'Suppliers and Sources' only as this is for members only and affords a degree of privacy on discussions without making them public.
