Sony 9-306
Hi All,
A while ago I requested some service info for the diminutive Sony 9-306UB set, which Chris was gracious enough to provide via the library.
I thought some of you may wish to see what's happened so far ....
The video is rather long and, quite frankly a little boring. Great if you're suffering from insomnia!
Part II coming soon!
All the best,
Doz.
Part II should be up in a couple of days.
625 works well enough now. There's something smearing the video a bit on both standards, but I haven't tackled the signals board yet.
405 not so good. Line linearity is awful. Frame lin isn't great either, and the settings that work OK on 625, aren't happy on 405...
I haven't had much time to attempt a proper set up as yet.
I also watched Part 1 with some interest, having one of these sets on my 'to do' pile. I've had a brief look at it. Mine has a frame fault on 625, two pictures can be seen at once, one slightly squashed above the other. 405 not tested. I took the same approach, changed a couple of 20uF capacitors on the timebase board which measured out of spec, but the fault remains.
Just a comment: I don't usually replace old unsleeved 13A plugs unless they're badly damaged. Having a modern plug on a vintage appliance seems a bit odd to me. However, I do replace 13A fuses with something more suitable.
With regard to unsleeved 13A plugs......these can still be used as long as they are in good condition of course and you can continue to use them on your own equipment. What you can't do is pass the equipment on to someone else with the old style plug fitted. So if you do pass it on or if you are repairing something for someone else then you have to change the plug for a new sleeved type. You can give the old plug back to the customer who is quite at liberty to refit it and use it.
In short, it's not illegal to use these on your own equipment.
The plug had a chunk out of the plastic too... it's skip fodder.
Can't wait for episode - Where, if memory serves me, Meg finds Sandy in the broom cupboard with Amy Turtle?
Now, you can bet your bottom dollar, if that had been my telly, I'd have had wires pinging off the boards all over the place, and would have fried those irreplaceable Japanese transistors.
Posted by: Katie BushCan't wait for episode - Where, if memory serves me, Meg finds Sandy in the broom cupboard with Amy Turtle?
I'll give you a clue, it's not professor plum in the drawing room with a 2SC41.
Spoiler alert... damn thing gives me a belt in the next episode!
Hi Andy, have been enjoying your videos on this little Sony so far 🙂 I revived a similar model in the same era as yours a 9-304UE and ended replacing every single electrolytic in the thing they were all off the scale! Needless to say the things performance vastly improved afterwards and I also battled with getting those caps out of the boards with their folded legs and trying not to lift the tracks in the process! If you're interested in seeing some videos I did on it have a look at my You Tube channel 🙂
Look forward to your next episode on the Sony ?
Cheers, Glen.
Posted by: glenz75Hi Andy, have been enjoying your videos on this little Sony so far 🙂 I revived a similar model in the same era as yours a 9-304UE and ended replacing every single electrolytic in the thing they were all off the scale! Needless to say the things performance vastly improved afterwards and I also battled with getting those caps out of the boards with their folded legs and trying not to lift the tracks in the process! If you're interested in seeing some videos I did on it have a look at my You Tube channel 🙂
Cheers, Glen.
That timebase panel looks very familiar! What are the two big transistors top right? I must watch the video all the way through later (probably while my part 3 is rendering!)
Hi Andy, I think from memory with those two large bits of silicon, one is the lineoutput and the other may be a power supply regulator? Am not 100% on that will have to relook myself! ?
Posted by: glenz75Hi Andy, I think from memory with those two large bits of silicon, one is the lineoutput and the other may be a power supply regulator? Am not 100% on that will have to relook myself! ?
Power supply regulator... now there's posh. Mine has no such refinement! If the other transistor is the line output device, what's top right of the timebase board? That's where my lineo utput transistor is (a 2SC41) , and yours appears to be populated there too.
Well it turns out I was totally wrong! ? After consulting the street map, the two transistors top right 2SC41's are both for the horizontal output and the other one the single heatsink near the middle of the board 2SB232 is the vertical output. Did you ever find out what gave you that arm jerking belt in Part 3?
Posted by: glenz75Well it turns out I was totally wrong! ? After consulting the street map, the two transistors top right 2SC41's are both for the horizontal output and the other one the single heatsink near the middle of the board 2SB232 is the vertical output. Did you ever find out what gave you that arm jerking belt in Part 3?
Thanks Glen. I didn't get to the bottom of it... I've just put it down to experience...
Disaster has struck.
Just about to film the last bit of part 4, having given the IF a fresh new supply of electrolytic capacitors. Pictures were really good. All of the nasty smearing eliminated... Just as I'm about to press record on the camcorder, something goes "crack".... sounded a bit like a touch of EHT flash-over.
No sound or video on 625 .. a bit of sound on 405.
Tracing through with the spec-an, and I've lost the first IF transistor. It's a 2SA456. Germanium IF: 1 mA; US: 0.5 V; Isp: 30 µA; ß (beta): 48; N: 60 mW; Imax(Ic): 10 mA; Umax(Uce): -(22) V; f g(FT): 300 MHz; tmax j: 85 °C; 0.6 pF.
Has anyone got or suggest an obtainable replacement?
Hi Doz, sorry to read the above.
I believe an AF239 is an equivalent and there are a selection on ebay at not too silly prices.
- 7,989 Topics
- 15 Online
