CRM123 CRT required
TVJON74
(@tvjon74)
Honorable V-Ratter Registered
I know this is a long shot, but does anybody have a CRM123 CRT needing a new home? Or any other suitable substitute suggestions?
TIA
Topic starter Posted : 24/06/2018 11:22 pm
MongooseDC
(@mongoosedc)
Not sure what a CRM123 looks like, but there's a nice old CRT presently for sale in Northamptonshire on a certain auction site that may be of interest to VRatters!
old round crt
Posted : 14/12/2018 2:04 am
The CRM123 is physically identical to the older CRM121. The differences are the CRM123 is aluminised and is made to work on a >7KV EHT supply. Same heater ratings as the CRM121, 2volts@ 1.3Amp.   Alternative Mazda tubes: consider the CRM122, but you'll need a separate filament transformer for the 7.3volt o.3amp heater.   CRM124 is a 9KV tetrode, 12.6 0.3amp heater, has a B12A base.
The Mullard MW31-16 and MW31-74 are tetrodes. 6.3volt 0.3amp heaters. >7KV.  Like the 12" Mazda tubes have the 35mm neck.
Posted : 14/12/2018 11:33 am
TVJON74
(@tvjon74)
Hi both,
Thanks for the replies.
This tube is required for an Ekco TC185 that is in very good and clean condition, but sadly has no back and a necked CRT that I guess has happened due to the lack of its back.
I think I have a couple of 12 inch round CRT's but I have no idea what they are!
Topic starter Posted : 14/12/2018 3:21 pm
