Ferguson 3792 22"
6 Users
63 Reactions
(@raster83)
Hi Folks, got an issue with my Ferguson 3792, it's been working great since I acquired it, but last night without warning the whole tuning system suddenly failed. You can see from the attached photo there's a raster clearly there still and some quite white noise through the speaker, so amplifier and frame out stage are obviously working fine, but no snowy screen on any channel.
Checked the TDA2540 demodulator IC and it seems to be getting 12v to the appropriate pins, so the power supply must be working to that part of the circuit.
Any advice on how to continue diagnosing this issue would be much appreciated.
Screenshot 20190916 080131 Gallery
Posted : 16/09/2019 7:10 am
acj1980, acj1980 and acj1980 reacted
(@acj1980)
Posted by: @raster83
try to measure on the tuner, if you can locate around 38,9mhz from it, you can locate the fault to to IF, do you have a schematic? i would like to watch 🙂
Posted : 16/09/2019 8:51 am
To help @Raster83 and aid further investigation/member discussion, here is the signal processing circuit
tx9if
Posted : 16/09/2019 9:33 am
Raster83, acj1980, Raster83 and 3 people reacted
A clean raster normally points to a tuner/IF fault.
Posted : 16/09/2019 9:38 am
(@acj1980)
it seems to be easy, if we have raster on the screen, and the tuner works, the fault has to be tda2540, but try to measure the voltage to it, maybe its gone?
Posted : 16/09/2019 10:38 am
(@raster83)
@acj1980
Thanks for that, managed to track down a schematic thisafternoon so will look into that
Posted : 16/09/2019 2:42 pm
(@raster83)
@acj1980
Managed to get a service sheet for the TDA2040 cause I had my suspicions about that going, got 12v going onto it, so the powers supply is ok, seems a cheep part to get, so might try swapping that out
Posted : 16/09/2019 2:48 pm
(@raster83)
@cathovisor
It died very suddenly without warning so did I wonder if it was something to do with that board.
Posted : 16/09/2019 2:55 pm
Does sound like a faulty TDA2540 or SL143x, note there are two version of the PCB. In early version the SAWF driver was a Plessey SL1430 which was extremely reliable, the same cannot be said of the later SL1432 which usually caused very low gain and they are not interchangeable. The set will still produce snow even with no tuner fitted.
Posted : 16/09/2019 6:41 pm
(@marconi_mpt4)
TDA2540 seldom fails, but often have found capacitors in the AGC circuit give blank raster symptoms and would suspect C47 (0.1µF ) electrolytic capacitor, or maybe (horror) tantalum shown in the schematic excerpt posted by Chris. Also C35 (1µF ) and C36 (22µF) might be worth a look.
Posted : 18/09/2019 9:50 am
Posted by: @jayceebee
Just to clarify you can fit a board using an SL1430 in place of one using an SL1432 and vice versa, it's just the ICs which are not interchangeable.
Agree with Rich that failure of the TDA2540 and also the SL1430 was very rare, don't think tantalums were ever used in the TX series.
Posted : 18/09/2019 7:03 pm
Raster83, Red_to_Black, Raster83 and 3 people reacted
(@raster83)
She's Alive! Thanks folks, you were right, it was the TDA2540 on the IF board. Many thanks for all your help and suggestions. It's always a huge sense of a achievement being able to keep these great old sets working. ?
Screenshot 20190919 185428 Gallery
Screenshot 20190919 185327 Gallery
Posted : 19/09/2019 6:03 pm
acj1980, malcscott, Cathovisor and 12 people reacted
Great news, I can see the main PCB is a PC1044 type which was the best version of the TX9. ?
Posted : 19/09/2019 8:25 pm
(@acj1980)
@raster83
Great she´s back to life, great picture , i really like the design, how old is the TV set? i guess around 1980-1982 🙂
Posted : 20/09/2019 5:30 pm
(@raster83)
@acj1980
From the research I've done, it's from 1981, so your right about the era, the case is actually plastic made to look like wood which narrows it down to that time.
It's a great picture considering the age, according to the folks I brought it from it was actually used as a main telly up untill recently, so a tribute to the reliability of these sets. Incredible sound quality too on these, nice warm deep tone from the large elliptical goodmans speaker.
Posted : 21/09/2019 4:25 pm
Posted by: @acj1980
You should have looked in the colour brochure section of this sites blog, there's a whole section dedicated just to Ferguson. It covers many of their colour TV's from 1967 - 1986, your set is there for 1982 see below.fergtv03
Posted : 21/09/2019 6:29 pm
