MATSUI 1407R - Modi...
MATSUI 1407R - Modification for AV In
6 Users
ChasL001
(@chasl001)
Eminent Member Registered
Hello all,
It's been a while since I posted here, apologies, I've been busy.
I've just acquired a couple of MATSUI 1407R 14inch TVs which I hope to convert into Retro Monitors.
I have some manuals for the 1403 and1408 but can't find one for the 1407R.
Anyone know if the chassis is identical to these two?
In the Circuit for the 1408T (the Teletext version), it has RGB inputs which could be modified for external inputs but the models I have 1407R (Remote version) has no text and no external inputs.
The circuit for the 1403, it shows AV in and out sockets and I'm hoping the 1407 will have them to, if not populated, so I should be able to get CVBS in at least.
The 1408R shows SCART connections and RGB connections for OSD purposes, so again, if the 1407R has similar circuitry I hope to add external RGB and or CVBS input.
So, hoping someone might have and be willing to share a 1407R circuit diagram if not the service info for it, I'd be very grateful. Appreciate I've not posted enough to qualify for the VRAT data library access.
I'll post here as I progress - or not - with this project.
Thanks
Chas.
Posted : 24/11/2024 6:35 pm
Hi Chas,
Your best chance of finding this data is with member @michael-dranfield his collection of manuals is legendary. As I've used the mention feature of this forum, Michael will have received a notification of this thread.
Posted : 24/11/2024 8:39 pm
Michael Dranfield
(@michael-dranfield)
I can have a look tomorrow, it's a long time since I did CRT for a living so I don't just recognise the model number off the top of my head but I did do a lot of mastarcare stuff in the 80s and I have kept all my service manuals.
Posted : 24/11/2024 8:50 pm
irob2345
Needless to say you should check that the reason there are no external AV inputs is the TV might be live chassis, rendering it unsuitable for conversion. They might have used an alternative, more expensive, isolated PS in TVs built with AJ connectors installed.
Posted : 25/11/2024 7:43 am
Posted by: @chasl001
Hi Chas, only just spotted this, it's not true, you've had access to the data library pretty much since you joined, it's just there is nothing in there.
There used to be over 10,000 items in our online library, and I have much more that wasn't yet scanned. It all had to be removed due to running out of server storage, though I have a copy on my PC. Now it's just a temporary staging area, manuals get copied in then deleted as and when requested. Yesterday I looked in all my cabinets, and my PC, nothing for Matsui 1407, which is why I reckoned if Michael does not have it, you're unlikely to find it.
Posted : 25/11/2024 8:16 am
ChasL001
(@chasl001)
Posted by: @michael-dranfield
Thanks Michael, appreciate it if you find even a cct for this particular model.
Posted : 25/11/2024 8:57 am
ChasL001
(@chasl001)
Posted by: @irob2345
Yeah, appreciate that, hence the need for the cct before I even begin, haven't even taken the back off yet.
I expect it's going to be a no-goer, but to pick up a couple of these for a quid each was a bargain I could not refuse.
I remember teaching trainees about working on live chassis when I was a TTI, so I'll just have to try and remember what I taught all those years ago 😉😉
Posted : 25/11/2024 9:00 am
ChasL001
(@chasl001)
Posted by: @crustytv
Thanks, my memory must be playing tricks, I seem to remember you had to post xx number of times before you gained access to the library. Oh well, Nurse! ...
Posted : 25/11/2024 9:02 am
I can remember seeing a range of sets which although not having an isolated SMPS it had external inputs using opto couplers. There still must a been a small mains transformer though to feed power to the cold side of the opto’s. Not sure of the brand, Hitachi maybe?
Posted : 25/11/2024 10:41 am
ChasL001
(@chasl001)
Well progress of sorts on the project.
1. The sets work - Bonus, one of the two remotes also works
PXL 20241125 144444713
2. Whilst this set has no AV inputs, the chassis must be one used by multiple models made for Currys Matsui brand, as there are holes in the PCB for mounting a SCART Socket.
PXL 20241125 144524531
PXL 20241125 144512430
3. Given 2 above, the worry about Isolation is minimal, as it has a fully isolated SMPS PSU and the ground pins of what would have been the SCART connector (Pins 4, 5, 9, 13, 14, 17, 18 & 21 ) all go to the ground on the COLD side.
The not such good news side is that none of the Matsui 14xx series manuals I have found have the same major ICs as in this board.
IC601 - Video signal processing = TB1229N
IC103 - System controller? = OEC6047B
IC850 - Teletext = CF70195NW
The datasheet for the TB1229 shows it has switchable Video inputs and both Analogue and Digital RGB inputs for Text and presumably input from the SCART socket if it was fitted. I have yet to check where the input connections go. If just terminated with caps, then I can probably feed in computer RGB and on the CVBS side, break into the Video input instead of the tuner.
The set was built around 1995 - 2000 as the manual for the 1403 states it as being 1995. I've checked the few back issues I have of Television Magazine but they're older, similarly my copies of Television Servicing.
Some time back I found a Television Magazine Index on the web which listed all the makes and models that had been featured, blowed if I can find it now. Anyone???
So I'll begin mapping out the connections from the vacant SCART pins and the components, in the hope I can use similar interfaces on other models the re-create the inputs and there's an area on the back cabinet perfect for mounting sockets.
Posted : 25/11/2024 3:43 pm
Michael Dranfield
Managed to find time to have a quick look today and I can't find the manual for the model you want but this doesn't mean I don't have it as there are many different names used for these orion based sets, take a look at the photo to see what I mean, if you could find some other names used for this set it would be useful, also a photo of the chassis might help.
IMG 20241125 100925
Posted : 25/11/2024 6:59 pm
Michael Dranfield
Now I see your chip line up I have another idea, I will check again in the morning.
Posted : 25/11/2024 7:13 pm
ChasL001
(@chasl001)
Here's some pics of the PCB with number which may help.
PXL 20241125 193633446
PXL 20241125 193508820
PXL 20241125 144740073
PXL 20241125 193647857
Thanks, appreciate it.
Posted : 25/11/2024 8:51 pm
ChasL001
(@chasl001)
Just realised, the set is a 1407S not a 1407R as in the thread title, sorry. Can that be changed? I changed this post title.
Posted : 25/11/2024 10:03 pm
Michael Dranfield
Sorry, no luck yet, thus is the one I was thinking of but totally different.
IMG 20241126 162115
Posted : 26/11/2024 6:14 pm
ChasL001
(@chasl001)
So with Deerstalker firmly in place and Lens to the fore, I was determined to find out more about this set. I tested the other set and that worked fine - as a TV - so that made me more enthused about this potential modification.
I found a website (there are several) which had a spreadsheet of Make/Model cross references, I expect it's already here on the forum but if not let me know and I'll upload it. Suffice to say, it did indeed list the Matsui 1407 see screen grab
EXCEL KVy5pGLbCF
As you can see, it correctly shows the 1407 as an Orion model with the PCB Marked TM784A as does mine.
Also, it states that the 1407 is the same as the 2107N. I found a manual for that set and it categorically is NOT the same, different chips throughout!
So next, I thought, I wonder if anyone else has had these difficulties and searched high and low through different forums to no avail.
Then, by chance, I came across good old TELEVISION magazine. I searched the ones I had, but they only go up to the late 80s. Then I found a website that has copies for practically all the years it was published. I downloaded the copies from 1990 to 2005 and searched them for anything related to a Matsui 1407. I found one instance where Eugene Trundall reported a fault on one. I looked at my set for similarities but what he worked on was not what I had.
Getting more and more frustrated, I just kept searching anything Matsui, Orion, 14" TV. Several times I doubted my own eyesight and gave up.
Today I thought I'd take another look, having found a datasheet for the Jungle Chip IC601 - TB1229CN, I found the sheet for a TB1229DN, close enough. It has AV switching built in but that controlled by the I2C BUS, which I could probably hack - I built a Memory Chip reader for the engineers at Mastercare years ago. But I wondered if using the remote I could force the AV switchover. The sets remote has some hidden contacts on it for probable use with another model, but these didn't activate AV, nor did a one-for-all remote programmed with almost every other Matsui code, the set would only respond to the original remote or one code ((0)147).
So I put the back on the set and was about to put it out in the shed when I noticed something odd, see the pic below:
PXL 20241203 173133653
 Can you spot it???
Well, it seems the model number is Not 1407 as in ONE FOUR ZERO SEVEN, but
ONE FOUR OH (capital letter O) SEVEN.
Sadly however, this has not helped in my search, still no circuit diagrams for this model found.
Looks like I'll have to put this aside for the foreseeable future.
Posted : 03/12/2024 6:11 pm
irob2345
AV inputs were often selected as a channel number - you could get to AV In with the Channel Down button.
We used to program our AV automation systems to turn the TV ON (regardless of its current state) by hitting a Channel Up button. Then, to select AV In you'd first hit Channel 1 and then the Channel Down button.
There used to be a website called www.remotecentral.com. Sadly it now seems to be gone.
Posted : 04/12/2024 10:11 am
ChasL001
(@chasl001)
Thanks, I was aware of the Channel buttons taking you to AV input but this seems not to be the case with this model. I suspect, that as there are no AV inputs, this option has been programmed out. The channels are programmable but Ch 0 can't be set. I'll give the Ch1 then down option a go but I think I've sort of done that already.
Posted : 04/12/2024 1:52 pm
Doz
 Doz
(@doz)
Put a  voltage on the "space" for scart pin 8, see if it switches?
Posted : 10/12/2024 8:26 pm
ChasL001
(@chasl001)
Posted by: @doz
Hi DOZ, good thinking, however, there are no connections to any of the pins, no links caps or diodes. I therefore traced the Pin 8 wiring all the way back to a pin on the MICON and toggled that with 12V, it blanked so looked hopeful but didn't display AV on the OSG. I held the 12V there for a couple of seconds and the set just shut down. So good idea but no cigar 🥲
I've also tried three remote controls with MATSUI codes and those that work control the set as normal, no special functions appear - except for the service menu (TV Vol - & #6 on RC) but even that does not offer any options. I even tried programming the set' EEPROM with the codes for a different model that has AV in but that failed too. So I very much suspect this is the end of the road for this project.
If anyone wants either or both these sets for spares, they are both fully functional, please let me know to make arrangements. FOC for anyone who wants to collect from Chinnor, Oxfordshire or pay the shipping and I'll send one/them.
Thanks for all the help and guidance, I'll try and find another 14" with AV in or to mod to use as a test screen for my workshop.
Posted : 13/12/2024 1:06 pm
You may have missed
