Sony GDM FW900 no picture/OSD - used to power on despite of the long therm problem
Hello, I have this old CRT Sony F900 monitor and I have been using him every day for the past 20 years. All I am asking, if possible, for a tip, on where I should start my investigation, my knowledge about the signal process in CRT is marginal.
The most recent measurements around IC620 MCZ3001D SW REG CONTROL are on the very bottom.
The link to the service manual is here https://drive.google.com/file/d/1D-sZZZDAH7SM4-e3q_wcBfSZUcg4pnRc
I was trying to reach many places before I decided to write to you. At this point, I understood, from the people and services I have tried to contact no one would even like to talk about CRT monitors.
I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute. I can make measurements in any state, check anything you would suggest, and record videos from the measurements. If you would like to go with me on this journey I would be thrilled. I have some knowledge mainly from your electronic repair guide blog, crt youtube repairs, and forums post, I just have a big mess in my head.
How it started
- It started with a bright and greenish picture upon starting a cold monitor.
- About 2 years ago, only on the cold boot, the screen started to occasionally flash with a green picture with retrace lines.
- About one year ago, when the screen was flashing on a high resolution I had to switch the input to only the OSD menu because in another case the screen would turn off and the diode would start to blink orange.
- At this point, I started turning on the screen with 640x480 resolution to the moment he will warm up.
- Always after the power station was turning on and off electricity, the issue started to progress. Basically, the electricity was cut off from the monitor a few times in a row in a very short period of time.
- After a few episodes like that, the screen started flashing red instead of green.
- After a few months, it was green and red in a similar proportion. The monitor had to be warmed up by switching INPUT 1/2 to calm him down.
- I have decided to keep him turned on all the time. He was working from one electricity shutdown to another.
- After another episode with electricity, I couldn't power him on. I need to press the power button on and off for 20 minutes to finally succeed.
- At this point, the only way to power him on was by pressing power on and off and changing the inputs from the front panel. He needs to stabilize and I won't do anything he will turn himself off like in this video
- The last few times I was able to power him after heating his back with a hairdryer. When he was turning on he wasn't flashing red or green. He was warmed up.
- At this point, I have stopped trying to power him on. There is a big chance that I would be able to turn him on but in the long run, it's pointless.
From the observations
- When the monitor will luckily turn on there are absolutely no issues as long as he is displaying the picture. When the monitor will lose power or will go to standby mode it is not working and cannot be turned on.
- When the monitor will somehow turn on it is flashing green, red, or both. It depends on the room temperature.
- If he receives a high-resolution picture from a graphic card (higher voltage needed to operate) he is flashing green and red and goes to the standby mode and cannot be turned on again. He cannot stabilize
- It was required to keep him on 640x480 dpi until he will warm up
- If the back of the monitor was preheated with a hairdryer from the sides and turned on there is no green and red flickering and can instantly operate on higher resolutions with no issues. If he will luckily turn it on.
- When he cannot be turned on and there is no graphic card connected to the monitor the led is green and goes to standby mode. There is no OSD menu displayed at all or green INPUT subtitles on the screen.
- If he has a graphic card (first video input 1) connected, the monitor after a few seconds starts blinking orange - no light - orange no light infinitely. In the video below I am switching from INPUT 2 (no source) to INPUT 1 (VGA source). For BNC sources the same situation. There is no OSD menu displayed at all or green INPUT subtitles on the screen.
At this point what I have tried
- I have dissembled him and could not find any burned, discolored, odd electronic elements.
- I couldn't spot any cold joints with a magnifying glass.
- Tube, Flyback, and caps are unlikely the issue (the guy who is having the same symptoms on the video had replaced every single cap across all of the boards)
- Heating up is not helping anymore
[Voltages that are going out from the G board when the monitor is powered on]
CN651
7V = 7V
CN650
STB5V = 5V
1W5V = 5V
ECO SW = 5V -> po chwili 3.5V
HTR SW = 4.9V
DGUSSW = 4.8V -> 0V
PWR SW = 5V
CN652
STBY5V = 5V
1W5V = 5V
+80V = ~15V for 1/2s -> 0V
+220V = ~90V-200V for 1/2s -> 0V
+12V = ~3.43V for 1/2s -> 0.04V
HEATER = 5V
CN653
+15V = ~1.36V for 1/2s -> 0.02V
-15V = ~2.43V for 1/2s -> 0.02V
+80V = ~3.8V for 1/2s -> 0V
CN653
H CENT H = ~4.3V for 1/2s -> 0V
H CENT N = ~6.3V for 1/2s -> 0V
H CENT L = ~7.2V for 1/2s -> 0V
+220V = ~15V for 1/2s -> 0V
G2 Voltage on A board = 0.00V
[G board (Power Supply)]
Measurements around IC610
C611 = 420V - (10) CATHODE but according to the Service manual it should be 376V
R643 = 0.0V
R629 = 0.0V
C639 = 9.3V
C648 = 14.8 V
R625 = 0.00V - should be 192V - (16) VG (H) (IC620 MCZ3001D SW REG CONTROL)
Those 2 resistors are on the red line going straight to (8) VC1 (IC620 MCZ3001D SW REG CONTROL)
R631 = 0.9V
R696 = 3.1 V
Out from VCC z IC610 - red line
R614 = 2.5V
C613 = 13.5V
C611 = 250V it is connected to (3) AC SEN IC610 (but in the Service manual it says it should be 86.2 V)
R620 = 0.0V
C643 = 0.15V
R621 = 97.0V
I don't understand what is going on with the R651 resistor, he is not present in any service manual
R651 = 73.0 V (photograph below)
The leg of R651 is connected to (1) V SENSE and the voltage across resistors is
R651 and R621 = 402 V is connected to (1) V SENSE of (IC620 MCZ3001D SW REG CONTROL) but in the service manual is printed it should be there 1.7V
C645 = 2.2V (3) CT - OK - Service manual = 2.2V (IC620 MCZ3001D SW REG CONTROL)
C647 = 0.00V (6) TIMER - OK - Service manual = 0 V (IC620 MCZ3001D SW REG CONTROL)
Here, does it mean that C646 is failing and needs to be replaced?
C646 = 0.17V (7) SS - WRONG - Service manual = 4.5V (IC620 MCZ3001D SW REG CONTROL)
I don't understand why when I am touching with only one prob of the multimeter on the legs of C646 I have 2.7V readings (the 2nd probe is in the air, not touching anything)
C640 = 10.8V (10) VC2 - OK - Service manual = 10.3 V (IC620 MCZ3001D SW REG CONTROL)
C642 - 0.00 V
R625 - 0.00 V
R626 - 0.00 V
UPDATE:
I have replaced C646 (2.2uF 50V) now I have voltage on him
C646 = 28V, the weird part is the monitor woke up and gave a screen with an OSD picture. But the picture was very bright with a greenish picture on it. I turned him off and was able to turn him on one more time. Now, when I turned on the monitor no change, but the voltage on C646 is present. But when I put a multimeter on C647 to measure voltage the monitor powered on again (only a few times).
I have replaced C646 again and noticed, the monitor power on the first try. Only once, again very bright. When he was heated with a hair dryer there was no over brightness.
I think the monitor was powered on because he was heated in this area.
Used to be C646 = = 0.17V (7) SS - WRONG - Service manual = 4.5V (IC620 MCZ3001D SW REG CONTROL)
Correct: now when I heat back the area for 15 seconds with the hair dryer he is always powering up very bright (I am turning him off, don't wanna harm him). Not sure how to locate which component needs to be heated (failing) and needs to be replaced. Any ideas?
The area that needs to be heated (only 15 seconds):
imgur.com/a/F77TQ5V
Any hairline cracks in the PCB? Or damaged tracks in the PCB?
This is why I prefer to do the absolute bare minimum to get something working then change electrolytic capacitors in stages, test the set, replace a few more, test again and repeat until done. At least this way if a new fault occurs you can backtrack to where you've just recapped.
The other problem of course is with Sonys they're either an easy repair or a nightmare! No in-between.
Hey @wayned, I am fighting for my Princess's life but without proper knowledge is even harder.
I have updated but I need help with troubleshooting (the monitor is now turning on)
I have noticed that heating up IC620 powers on the monitor I think the 7 or 8 leg was responsible for that state. So I have replaced IC620 and the monitor is powering on every time but the screen is RED / GREEN.
I have noticed that heating UP (not IC620) but closely around gives a proper picture (black background and this color input osd)
I have replaced 3 electrolytic caps around C645, C647, C646 but no difference
I think that there is something that killed IC and is doing this color problem (later CRT has proper colors after a very long time warmup and switching input 1 to input 2)
Any idea which type of component might be doing that, caps, res diodes? In this area
The PSU output without heating the PCB
CN652
STB = 5V
80V = 79V
220V = 218V
12V = 12.0V
Heater = 5V
Moreover, when I turn the monitor on and off 5x times in a row each time, he has less red removed link
After 3 times, there is no red color anymore only green.
The picture is black after 2-5 sec -> green.
After 5 - 7, monitors turn on in the row picture stays black and has no color issue.
After that colors are normal permanently, this issue occurs only when the monitor is starting up and warming up.
Have no idea what is going on at this point.
I'm guessing that monitor's like this have some sort of auto-greyscale on power up, so something connected to that could be causing the issue? The heater being 5V, is that correct, or should it be 6.3V like a lot of other CRT heaters? As for the rest of the power supply measurements, they look close enough to me, so I wouldn't be concerned about them. I've downloaded the service manual for the monitor, what a complicated beast!!
Best of luck with getting it going, it'll be great once working again!
Lloyd.
I don't know if you've ever seen the Shango066 video on a difficult to repair Sony but I think this sums up everything! It's well worth watching:
Sony KV1820E color issues
1 year ago
Sony CVM-1330UB
2 years ago
1980's Sony PVM-1270Q monitor
4 years ago
Sony KV1320UB MKII
4 years ago
Sony Trinitron KV-1320ub, More B&W than colour... Help?
5 years ago
- 7,989 Topics
