Data Library; Load ...
[Solved] Data Library; Load Check
Admin
Vrat Founder
Can I ask members with Data Library access (extract from Db below), to check they can get into the service.
I've had a report via PM from a member that it fails to load. However, checking as myself and a "standard" user test account, shows no errors, it loads perfectly OK. I tested it on Chrome, Firefox, Opera and Edge, all worked.
Names will get struck off the check list as members report.
Current Library Members:
helloekco turretslug mendipviews PYE625
Cathovisor Lloyd Boingy The_Teleman
EmleyMoor mfd70 Tazman1966 Katie Bush
MurphyV310 Till Eulenspiegel malcscott Red_to_Black
Mikey66 Norman-Raeburn Hurty freya
jimmc101 brc_3000 Doz marc
neil1974 ntscuser hamid_1 TVJON74
abctelevision Jayceebee nuvistor Marconi_MPT4
acj1980 peterscott colourmaster sideband
jjl PaulGoggo1 jskinner97 Electrical
glenz75
Registered
Famed V-Ratter
Hi, no problem with me using Firefox.
Need to remember to "right click" to open or download files.
A usual double left click results in....
Registered
Illustrious V-Ratter
for me the library loads and I can drill down to an item but when I try and look at a specific item I get told that the item cannot be found.
Screenshot 2020 04 17 Nothing found for
It has done this on my laptop (W10.1909 and Firefox 75.0) and my phone (Android 9 and Opera 57.2.2830)
HTH,
Mike.
EDIT: Andrew's beaten me to it!
Admin
Vrat Founder
Thanks Andrew and Mike.
At least it appears to be loading OK for others too.
Indeed, double clicking to try to view a data library file is disabled due to path security. As you both rightly point out members need to right-click to download, this was detailed in the Library info page/FAQ.
Registered
Famed V-Ratter
I always forget to right click at first, but that's just me.
freya
Registered
(@freya)
Noble V-Ratter
All good for me
Registered
Noble V-Ratter
No problems here ?
Registered
Noble V-Ratter
Just had a go on the iPhone, managed to download a Philips TV manual! so it seems all is well at this end.
jjl
 jjl
Registered
(@jjl)
Trusted V-Ratter
It's working OK for me Chris.
John
Registered
Famed V-Ratter
Working for me ok on iPhone and iPad. ?
