Would anyone know if Television did an article on Servicing the Ferguson TX10?
As you may or may not be aware via the menu bar above under :-
Blog | Service Dept| Colour TV | Servicing the sets
I've been adding all the popular articles of the time to help assist folk in their endeavours. I have gaps in my later Televison mags so cannot find anything on the TX10. It would seem odd that they covered all the early chassis' and the later TX range but excluded the TX10. I suspect it might be in one of the missing magazines.
If I had easy access to my copies from '84 to '88, I could look it up...
Using this handy index...
http://davesergeant.com/dstv.htm
I found the main servicing article is from January 1989 page 192
Hope that helps
That explains it then, sods law I don't have Jan 1989
I'm sure I have a copy. I'll scan it
Uploaded ?
Thanks for the scans Mike, I've now turned them into a PDF and the TX10 article can now be found under the "Servicing the sets" section, along with the rest.
