In response to constructive criticism, the "Hot Link" bubbles are now more easily accessible from wherever you are on blog or forum. For example; be it drilled down in forum thread or a blog knowledge base article, should you wish to say jump to the data library, you can easily do so.
In case you're missing the obvious, they now reside upper most top right. Prior to this you had to always return to the forum homepage to find them, which in hindsight was cumbersome.
