Through necessity not choice, and as part of the cost-cutting, the Private messaging system was replaced last week (12th May 2022). This was also an opportunity to retire the rather less than reliable service data, donation system, and combine them into one service, the new free PM system. Thanks to Rich (Marconi_MPT4) helping me test its functions.
For more information on the functions of the new PM system, please read the FAQ here.
Five days have passed without comment, not because of it being so wonderful, but as hardly anyone visits, hence the PM system is, equally, hardly used.
Note:
The old system licence has now expired, and is due to be deleted on Friday 20th May 2022. If anyone has important info in the old system they wish to retrieve (e.g. members telephone numbers, home addresses or e-mail address), please contact me and I will arrange to load the old system.
This is on the proviso you get what you need there and then, I will not leave the old system up longer than it is necessary to retrieve what you need. Therefore, make yourself available to contact me and complete the task at the same time.
Ah, I did try to message Wayne last week, and it didn't work. I did wonder why, but I had another method of communication, so I went with that ... talking of which, @WayneD can you send the carrier pigeon back? 😀
It may have been as I transitioned from the old to the new. I would suggest those of you left at vrat have a play with the new system and perhaps pm me to test it out for yourselves. I've communicated with Rich ( aka Marconi...). FAQ give you an idea on how to use it.
Thanks Doz, I'll check, be back with an update shortly
I tried messaging @malcscott about the doublers but I don't think he got the message. I sent the same message on both the old PM system and the RatChat.
Hi Wayne, none of that is related at all to the new PM system.
By the way, the message you sent on the old system, was delivered to malcs in-box. The old system's log files confirmed this. The Rat Chat was also sent. Malc rarely logs in here now, and I suspect he never bothered to check either.
OK so you're trying to send a PM via the second method, as detailed in the FAQ. That being via the shortcut method, i.e you've gone to the user's profile you wish to message, and clicked on the Private message button.
So scroll down the screen, there should be a message box. All you're showing me is what I've highlighted in the red box, you should have the text box at the bottom of the page (see below).
If you don't see the text box, I'm sure it is there as when I log in as you, it is. Then please try the first method of sending a pm as detailed in the FAQ to see if that works.
Gotcha.
Got your message, OH dear, so that was it, not scrolling down. OK no fault with the system then. Also, it's nothing to do with your mouse wheel.
As we've established, the message box was there all along. The mouse wheel will work, the mouse pointer has to be out of the "start message" notification box, that is not a scrollable field, the mouse has to be on "the page", just move it to the right a little, and you will see your wheel works fine.
