VCR 1986 Ferguson 3V55; Boxed
4 Users
3 Reactions
Took delivery of this today, a very well looked after Ferguson 3V55 and still with its original box. My heart sank when I took delivery from the courier as there was a rattling sound. I thought great, blighters have been chucking it around and now something has broken.
20230802 125026
20230802 125159
20230802 125335
20230802 130033
20230802 130038
20230802 130059
20230802 130145
However, upon investigation, I found what appears to be some sort of purposeful stick. It reminds me very much of the plastic tool that was inside the Philips N1700, that was a tape guide cleaning stick, I wonder if this is something similar.
20230802 130425
20230802 130435
20230802 130504
Anyway, as you can see from the photos, it's in mint condition, I've been informed that this is basically the same as a 3V44, which I already have in the collection. I bought this as I specifically want a period correct VCR to go under my 1986 Ferguson FST 51A2.
The first thing I did was remove the battery backup for the clock, this sits on a little board on the front right of the unit. There was already mild evidence that it was causing corrosion to link pins, and on the underside, we shall see how things fair.
20230802 130550
20230802 130940
20230802 131126
20230802 131156
20230802 131927
20230802 131946
I powered up without drama, however, there was a flashing "Cass" message on the display. Pressing eject clears this message, and the clock is then displayed. I tried pressing the on/off button but nothing happens and of course if you try to insert as tape, you meet resistance due to the unit not being actuated.
20230802 132510
20230802 132511
20230802 132512
As I've often stated, I've zilch experience with VCRs. I don't have the Ferguson 3V55 service manual but do have the 3V44 manual, I'll have a look at that, and hopefully it might help point me in the right direction as to what this flashing 'Cass' means and if due to that it prevents the unit from being soft powered on/off.
Edit:
Just as I posted this, I disabled Nob-Head mode!
I figured out the timer button was depressed, durrrr!.. Once I pushed this, the timer was off, and now I could soft power the unit on/off. I inserted a tape, the carriage took the tape, lowered and then hung in the lowered position. I guess this is the clue to the 'cass' message. Pressed eject and the tape comes out.
Now to investigate why it fails to load the tape. First things I will do is remove the carriage and clean the worm drive and lubricate. Clean the tape guides/path and lubricate, clean the heads, including upper and lower drum, finally change the loading belt.
20230802 142928
20230802 143243
20230802 143258
20230802 143352
Posted : 02/08/2023 12:52 pm
Lloyd reacted
Despite do all the above, and finding a piece of tape wrapped around the base of the pinch roller, the tape load still seizes mid-load. When the tape carriage was out for worm drive cleaning, I manually ran it through it sequence, it runs the full load to unload.
20230802 162504
20230802 145604
20230802 145636
20230802 153047
Looking more closely, it does take the tape correctly and lower into the correct position. What is not occurring is the head-spin and lace-up. Think I'm going to need John on this one.
20230802 155031
Edit
I wonder if it's Q604 the drive transistor? This is listed in stock faults for the 3V45 for no play FF etc
Posted : 02/08/2023 2:40 pm
Wonderful machines apart from just a few common trouble spots, CPs (fuses that look like transistors) which blow if you are not very careful, cassette detect switches on the carriage but they appear to be fine, that NiCad of course and the horrible graphite grease.
When you say it freezes after inserting a tape do you mean none of the function buttons work or does it stop during lace up? if it's the former try putting a tape in (not with valuable material on it) with the record safety tab removed. If it's an issue with the control micro, possibly death by Varta, then with said safety tab removed the machine should go automatically into playback.
Posted : 02/08/2023 3:06 pm
As above
Posted by: @crustytv
I was wondering, if it's Q604 the drive transistor? This is listed in stock faults for the 3V45 for no play FF etc. Doesn't mention no lace-up though.
20230802 160930
Posted : 02/08/2023 3:10 pm
Guess that idea was a no no then
20230802 161316
Posted : 02/08/2023 3:14 pm
Hmm.. Now this is almost to the letter the symptoms I have. Listed in 3V55 stock faults.
fault
Posted : 02/08/2023 3:19 pm
It's possible, those STK regulators could fail in various ways. Do you have any, but before you change it measure all the CPs on the PSU. Unfotunately there can be quite a few changes in the PSU from the original manual, some versions had extra CPs fitted
Posted : 02/08/2023 3:35 pm
I can't even locate it in the machine, not sure if I have any in stock, it's not a part i'm familiar with.
Posted : 02/08/2023 3:38 pm
@crustytv
Unfortunately I only had a couple of years experience with VCR’s and they were new so little trouble.
I can only watch and let you get on with the repair.
Posted : 02/08/2023 3:39 pm
I know what they look like now, but blowed if I can locate it. 🙄
Posted : 02/08/2023 3:43 pm
You wont, just dawned on me that was used in later machines. FV11R and FV21 series. The FV11R looked similar to the 3V55 but darker trim.
Posted : 02/08/2023 4:14 pm
Even though the stock fault manual clearly stated 3V55 had one! Bloomin marvellous, Well I'm stumped on this then. What about the optical mode switch, could that have failed?
Posted : 02/08/2023 4:20 pm
I doubt it, normally won't FF or rewind. Just to be clear, when you press play the drum does not spin and the guides start to lace the tape then stop and return? Check some voltages first on CN3 of the PSU, check all the supplies are up with the operate light lit. 3V44/45 manual will be ok to follow for this.
Posted : 02/08/2023 4:35 pm
I have just been over the power supply of the 3V55 checking the electrolytics. The only two that come up as 'In-Circuit-Leaky' are C5 and C12, both 33uF. This could be spurious as they were in circuit and could be perfectly fine, guess the only way to tell is to remove them.
With the absence of a manual and differences between the 3V44 and 3V55, it's a little difficult. However, if the PSU's are mostly similar, then the 3V44 shows that C5 and C12 are decouplers in the 5V circuit, I wonder.
20230802 171613
20230802 173600
Posted : 02/08/2023 4:40 pm
That cream fuse and holder show it's a very late version, it was originally an N25 CP on wires, there will be some differences in the circuit but don't go too deep yet. Just check the supplies on CN3, the drum motor board requires two supplies, unregulated 17V and unswitched 12V on PSU CN3 pins 8 and 7 respectively.
Posted : 02/08/2023 5:10 pm
I hate to say it, but I'm sure I've seen those bits of plastic used on hair curlers, Chris... maybe it's been 'posted through the letterbox'?
Posted : 02/08/2023 7:44 pm
crustytv reacted
Posted by: @cathovisor
I should count my blessings, it wasn't remnants of a jam sandwich.
20230802 185858
Amazing what havoc an intermittent joint can cause 🙄 A reflow of all pins on CN3 brought about life.
Faults I'm left with are a severely inadequate rewind. Search REW function is fine
Admin Edit:
VCR video clips removed from thread as it was slowing down the load time.
Posted : 02/08/2023 8:24 pm
Jayceebee reacted
Unfortunately the reel idler is a very small affair and was not available separately. You had to buy the whole reel drive assembly but it's not impossible to get at the idler and give it some rubber restorer treatment.
Posted : 02/08/2023 8:51 pm
