Panasonic nv-370
3 Users
(@acj1980)
Hello, it´s being a while since i was here, too much work to do unfortunally :-(.
I have this Panasonic with a strange error, when i plugged i in it was tottally dead, så i took a look on the psu (where the transformer is) that part was okay, later i found a open fuseresistor and replace it, then the display turns on, and after a while i could turn on the vcr from standby to on, i put in a cassette and press FF, rew and play, it was working, but after a short time it starts to do strange thing, going bank into stop and shifting between on/standby and at last goin to standby for good :-(.
There is still light in the flourcent clock, but nothing happens when i push the standby/on button in, there´s nothing burnt, no smell no nothing except the smell of cigarettes :-(.
does somebody in here have experience with this model?
Thanks for help
Best regards
Alex
20250521 200501
20250521 200425
Screenshot 20250507 191315 eBay
20250521 200555
20250521 200551
Posted : 23/05/2025 3:39 pm
@acj1980 I had one for many years from new, only fault was either the reservoir or smoothing capacitor, can’t recall which, you can see in the photos you have posted.
I would check all voltages supply lines, after that I have no other experience.
Posted : 23/05/2025 10:09 pm
(@acj1980)
@nuvistor it seems to be a common problems in these vcr´s, after a while the standby/on button was turned to "on" the vcr goes to on and works again until i blow som heat from the hairdryer around the power section, then it goes back to standby, so i think i have to take a look on the caps.
Another issue is the picture is very bad because of defective capacitors i think.
so i have a little job forward :-), i´ll be back 🙂
best regards
Alex
Posted : 25/05/2025 3:06 pm
Famed Member Moderator
What are those parallel 10 ohm resistors doing? Are they replacing the O/C fuse resistor? If so the fuse resistors are usually either zero resistance or very low value. I used to carry replacements and they are usually around 1 ohm so 5 ohms will be too high and might upset the operation. It was a very long time ago and Philips marketed their version of the machine as a VR6460 so I repaired a few of these. Not many major problems.
Posted : 01/06/2025 1:42 pm
